Welcome back:
Do me a favor, try this test and let me know what you find. The picture attached correlates with the test.
________________________________________________
1989 Plymouth Acclaim V6-181 3.0L SOHC
With Powertrain Control Module (PCM)
Vehicle Powertrain Management Computers and Control Systems Testing and Inspection Symptom Related Diagnostic Procedures No Start Test No Start (NS) Tests Ignition System No Start Test With Powertrain Control Module (PCM)
WITH POWERTRAIN CONTROL MODULE (PCM)
Fig. 2 Coil negative terminal jumper wire
Before proceeding with this test, perform "Ignition System Starting Test." Failure to do so may lead to unnecessary diagnostic time and incorrect test results.
1. Measure battery voltage using a suitable voltmeter. Battery voltage must be at least 12.4 volts to deliver the necessary voltage to operate the cranking and ignition system properly.
2. Crank engine for five seconds while noting voltage at coil (+) terminal.
3. If voltage does not remain near battery voltage during cranking, problem is contained within the SBEC engine electronics. Refer to the appropriate chapter in the "Fuel Injection Section" for diagnosis.
4. If voltage remains near battery voltage during cranking, turn ignition Off and disconnect 60-way electrical connector, from SBEC and inspect connector for any loose terminals.
5. Remove coil (+) lead, then connect suitable jumper wire between battery (+) and coil (+) terminals.
6. Momentarily ground terminal 19 of 14-way connector using a suitable jumper wire, Fig. 2. A spark should be present when ground is removed.
7. If a spark is present, replace SBEC. If spark is not present, use special jumper to directly ground coil (-) terminal.
8. If spark is present, locate and repair open in wiring harness. If spark is not present, replace ignition coil.
Also, let me know if you tried to get diagnostic trouble codes following the link above.
Aug 26, 2019 at 10:27 AM
