I had a high idle around 2000 rpm and surge while driving. I replace the coolant temperature sensor and now the idle is much better. The coolant sensor connector is good i.e. connector end are silver. On the other hand I do get a surge flux change up and down while the driving car i.e stall or rpm would drop to around 8000 or 9000. Also this time I got a code of P0108 then later P0107. I reset the code and recheck if any pending codes would occur. Any suggestion?
May 26, 2016 at 3:30 PM
