Car wants to stall when going uphill.
168,000 MILES • 1.0L • 3 CYL • 2WD • MANUAL
DEANNA YHALKEE
Have gone through and replaced idle sensor, spark plugs, wires, fuel and air filter cleaned and reinstalled EGR valve with new gasket did compression test and vacuum leak test everything good idles correctly now but still wants to stall when going uphill and poor gas mileage need to smog in a few weeks. Help!
Mar 25, 2017 at 11:44 AM
  • 55,746 POSTS
This sounds like the fuel pump is going out, here is a guide to help you make sure.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Mar 28, 2017 at 6:46 AM
