Car wants to stall
150,000 MILES
COLETURNER08
  • 22 POSTS
I just changed my clutch in my car. I started it and it ran. When I take it down the road I can hit 3,500 rpm's then shift to second hit 3,500 rpm's again then shift to third then it buck and back fires then when I stop it wants to stall. If I hit the gas a few times it starts to Idle again until I start shifting again. I noticed my negative battery terminal wire is frayed and when you touch it a rusty dust comes off and some of the wire is falling apart. Could this be my problem?
May 21, 2018 at 12:00 PM
  • 110,251 POSTS
Hi and thanks for using 2CarPros.com. Since you most likely disconnected the cable to do the repair, that could be the problem. That is the first thing I would repair. Since the engine is misfiring, I would also scan the computer to identify trouble codes. Here is a video for doing it:
https://youtu.be/YV3TRZwer8k
Let me know what you find.
May 21, 2018 at 12:33 PM
