Car wants to cut off but will not?
70,890 MILES • 3.5L • V6 • 4WD • AUTOMATIC
MWBROWNIII4
Every now and then my car wants to cut off, but will not. It started happening when the car is reverse, but now it does not matter if it is reverse or drive. A few times at a full stop it would not go into gear, even though I have it drive.
Jan 21, 2026 at 2:38 AM
  • 55,721 POSTS
Yep, this will happen if you have a vacuum leak, or the throttle body needs to be serviced. Can I ask if you have any codes? if you have not run them we need to. This video will show you how.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Here is how to check for the vacuum leaks.
https://www.youtube.com/watch?v=LRKWV4Are5c
This guide can help as well to helps service the throttle body
Read it through completely before you begin. Please go over these guides and get back to us. Ken
Jan 23, 2026 at 1:13 AM
