Car will not turn over
123,467 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
STEPHANIE HILL2
Car tries to start but won't fire up.
Dec 17, 2020 at 6:46 AM
Good evening,
Does the engine turn when you try to start or does it do nothing?
If it cranks over, you need fuel pressure, compression and spark. I attached some guides for you to follow.
I attached a wiring diagram of the starter system as well.
REMOVAL
1. Disconnect negative battery cable.
2. Disconnect shift linkage.
3. Disconnect electrical connector.
4. Remove mounting bolts.
5. Remove switch assembly.
INSTALLATION
1. Place shift shaft in "Neutral."
2. Align flats of shift shaft with switch.
3. Install mounting bolts, loosely.
4. Insert gage pin in service adjustment hole and rotate switch until pin drops in to a depth of 9.0 mm (9/64").
5. Tighten bolts to 24 N-m (18 lbs.ft.).
Dec 17, 2020 at 10:50 AM
STEPHANIE HILL2
Yes it tries to start.
Dec 17, 2020 at 11:00 AM
STEPHANIE HILL2
It trust to turn over.
Okay, you need to have the fuel pressure tested and see if there is any spark.
You can rent a tester at a parts store for the testing.
FUEL PRESSURE:
Ignition "ON" Engine "OFF" .................... 40.5 to 47.0 psi
With Regulator Vacuum Applied [1] ..... 3.0 to 10.0 psi Less than Ignition "ON" Engine "OFF"
REMARKS:
[1] May be checked with either of the following methods.
With Pressure Regulator Vacuum Line Attached at normal idle speed.
Ignition "ON" Engine "OFF" with 10 Inches Of Vacuum Applied To The Pressure Regulator.
Dec 17, 2020 at 11:06 AM
