Car turns over but wont start
1991 CADILLAC FLEETWOOD BROUGHAM
74,000 MILES
JOSUE MARTINEZ
Had low oil pressure light on changed oil pump and oil pressure switch now Car wont start it turns over but wont stay runing. Car turned on fine before changeing those parts Also changed oil pan gasket trans mission pan gasket and oil filter
Jun 30, 2013 at 4:17 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
You may have disconnected something. Check to see if you have spark to the plugs and fuel to the injectors. See if the vehicle will start if you use starting fluid. If it does, then you have a fuel related issue. If it still doesn't, check for spark and make sure the crank sensor wasn't damaged or disconnected.
Jun 30, 2013 at 9:21 PM
JOSUE MARTINEZ
Tried to start still turns over but still won't start don't think its fuel related can smell gas when turning over going to change spark plugs and see if that helps does any body know where the crank sensor is located.
Jul 8, 2013 at 8:10 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
I don't know why, but this just showed up in my mail. Sorry it has been so long. Have you had any luck with the issue?
Aug 10, 2013 at 9:39 PM
