Car turns over but will not fire
FRED STEINER
  • 2000 PONTIAC GRAND AM
  • 2.4L
  • 4 CYL
  • 188,000 MILES
Recently had a shop install a new fuel pump, filter, a couple of lines, regulator, charcoal canister. Car ran fine for a few months.
Now it turns over but will not fire. It started to idle poorly then shut off at a stop. Finally had to have it towed home.
Friday, November 16th, 2018 AT 11:05 AM
  • 52,797 POSTS
Good afternoon.
I would start by checking for spark and fuel pressure. we need to start at basics.
Do you hear the fuel pump turn on when you turn the key on?
Thursday, July 30th, 2020 AT 5:27 PM
FRED STEINER
Got it running. Camshaft sensor was pulled and found to be covered in metal particles, much like what is found on your magnetic oil drain plug. Wiped it off and car fired up. Replaced with new sensor.
  • 52,797 POSTS
Okay, good find. Now the question is, where did the debris come from? Something is wrong and it will happen again unless you find the reason why it happened.
