Car turned off while driving on the road?
2014 OPEL CORSA
160 MILES • 1.3L • 4 CYL • 2WD • MANUAL
ABBAS07227
I have encountered a problem with my Opel Corsa, it stopped running on the road and after 30 minutes it started again. i have changed the ignition coil and crankshaft sensor but the same problem, the car is powered by petrol and lpg . Thanks for the help.
Jul 26, 2024 at 10:54 AM
  • 110,241 POSTS
Please understand, this vehicle isn't offered in the US, so I don't have specifics to refer to. However, I will try my best to help.
When the engine stalls and won't restart, see if it will start using starting fluid. If it does and then stalls, we will know it is fuel related. If there is no change, I need you to recheck for spark at the plugs.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
One of the two things mentioned will be missing, spark or fuel. We need to determine which one it is.
Let me know what you find.
Jul 28, 2024 at 12:00 PM
