The rebuilt engine started and ran, now it will not start?
204,650 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
KRZYSZTOF
  • 32 POSTS
i rebuild the engine and it was running for 7 days. Now it doesn't want to start. i replaced the intake runner sensor, (2) camshaft sensors. The TPS light blinking and won't start. I checked all fuses, and they are okay. It has no spark and no injectors power. Is the crankshaft sensor related to spar or the injectors?
Sep 27, 2022 at 3:56 AM
  • 110,251 POSTS
Have you checked all connections at the PCM? Have you checked the auto shutdown relay and fuses? Is the starter turning the engine or not responding?
Let's start by checking fuse 26 in the under-hood fuse box and the ASD relay. In addition to checking the fuse, confirm there is power to it.
Here are two links you may find helpful when checking:
I attached a pic below of the fuse box and highlighted the fuse to check.
Let me know what you find.
See pic below.
Sep 27, 2022 at 12:21 PM
KRZYSZTOF
  • 32 POSTS
HI, i Coleen all the connection with starting spray, and i spray some carburetor cleaner to thread body and car start and running, now intake manifold runners stock open and gas pedal don work, the only code is for runners, replaced the sensor and steel shows is stock open. I'm going to take off intake Coleen runners and replace the accelerator pedal and see if work if not I'm going to take brake for cope days .
Sep 27, 2022 at 7:15 PM
  • 110,251 POSTS
I'm glad to know it at least started. If you can, let me know the codes that are present. Hopefully, I will be able to provide the diagnostics specific to the codes to help.
Sep 28, 2022 at 10:10 AM
KRZYSZTOF
  • 32 POSTS
HI, thanks for responding. i cleaned the manifold ranges and worked for a while now the code is back, and farther diagnosed i found exhaust cam sensor wires was melted, so i need to get new connector and sensor. i thing that was messing every up,im using AULET MAXIDAS DS708 i don know to much for programming bat i check for problems and is doind good work. when i fix those problems i let you know what is next. thanks
Sep 28, 2022 at 8:46 PM
  • 110,251 POSTS
Thank you for the update. When you have a chance, let me know how it turns out for you. I'm interested in knowing.
Sep 29, 2022 at 11:36 AM
KRZYSZTOF
  • 32 POSTS
Hi, so far so good, car is running. i manage do some work on A/C, is working good, bat two codes keep pope out on intake runners P2004 and P2015 and gas accelerator pedal don work, i replace runner sensor ,and I'm thinking to replace throttle body that is last thing i did not change. thanks
Oct 1, 2022 at 8:17 AM
  • 110,251 POSTS
The runner is stuck open. Have you been able to get that repaired? Also, the P2015 is related to the throttle pedal assembly. Have you done anything with that yet? I'm not sure what you mean by threado body. If you meant throttle body, don't do that until we go through the diagnostics for the present codes
Oct 1, 2022 at 1:35 PM
KRZYSZTOF
  • 32 POSTS
Hi Joe, i took off the intake manifold and cleaned and washed the runners, put back replace that electronic actuator solenoid, and throttle pedal. and yes, i meant throttle body.
Oct 1, 2022 at 10:50 PM
KRZYSZTOF
  • 32 POSTS
and i have not checked the wires test yet. i need to figure out how.
Oct 1, 2022 at 10:52 PM
  • 110,251 POSTS
Thanks for the update. Which wires need to be tested? Let me know as much as you can so I can help.
Oct 2, 2022 at 2:05 PM
KRZYSZTOF
  • 32 POSTS
Hi Joe, i menage calibrate accelerator pedal, the only code is p2017 witch i got a new from eBay and i install and run for 1 minute and the code come back again. I'm going to get 1 from parts store if that doesn't work i give up. thanks
Oct 3, 2022 at 2:47 AM
  • 110,251 POSTS
You would be amazed how many faulty parts I see people getting online. I have a feeling that is the issue.
If possible, let me know if that takes care of the issue. I'm interested in knowing.
Oct 3, 2022 at 1:29 PM
KRZYSZTOF
  • 32 POSTS
Hi, in order 1 runners' actuator online from AutoZone arrival is 4 days and see what happens. i think too many hands were the car digging and no one fixed anything just made it worse, let you know day or two. Thanks
Oct 3, 2022 at 10:22 PM
  • 110,251 POSTS
I noticed I haven't heard from you for a couple of days. I was wondering if the parts came in and how things worked out for you.
If you haven't received them yet, no need to get back to me until they do. I'm just interested in knowing.
Oct 6, 2022 at 12:01 PM
KRZYSZTOF
  • 32 POSTS
Hi, i got the part on Friday is factory aftermarket part i install and work, now is throwing transmission code. So, I'm going to drain the oil and change the filter and transmission fluid and see what happens. I will update you with codes, thanks.
Oct 8, 2022 at 7:03 AM
  • 110,251 POSTS
Thank you for the update. It sounds like you are making progress. Let me know what codes you find. Hopefully, I'll be able to help.
Oct 8, 2022 at 2:17 PM
KRZYSZTOF
  • 32 POSTS
Hi Joe, everything was going well, fix the engine intake runners, and now po700 and po755 are on. The transmission is not shifting at all. i changed the filter and transmission fluid, from this point i need help. i do not feel like pulling the transmission out and spending more money for new transmission. Help!
Oct 10, 2022 at 6:51 AM
  • 110,251 POSTS
You have the same kind of luck I have with my personal vehicles. LOL It never ends.
As far as the question is concerned, I have a favor to ask. We try to keep the threads specific to one topic, so it is more helpful to others. Is it possible for you to copy your new question related to the transmission to a new post?
Here is the link to start a new one:
I hope you understand. I will watch for the new question.
Oct 10, 2022 at 12:16 PM
KRZYSZTOF
  • 32 POSTS
Hi Joe, the codes po700 and po755 steal coming on even after replace solenoid pack with Mopar OEM it is in limb mode and stock in second gear, i tried to scan the gears and reset is show cool transmission all the time and won't let me calibrate the gears only gear shift will calibrate. i hope is not PCM. thanks
Oct 14, 2022 at 9:14 AM
  • 110,251 POSTS
I attached the diagnostics specific to the P0755. Take a look through them and let me know if they help.
Take care.
Oct 14, 2022 at 3:24 PM
KRZYSZTOF
  • 32 POSTS
HI THIS info is not apply to dodge avenger mi car have different wires colors there is no black ,the one on picture is yellow,blue strips. i found faulty speed sensor,(replace)and check all the wires nothing is brook ,mine next guess is pcm on trans side,thanks
Oct 16, 2022 at 2:29 AM
