Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Lesabre
Engine
Symptoms
Not Running
Engine turns over but will not start
1994 BUICK LESABRE
289,000 MILES • 3.8L • 2WD • AUTOMATIC
ROD789
MEMBER
1 POST
When I turn the key it turns but will not start or if it starts it will cut back off after a few minutes.
Mar 8, 2021 at 11:10 AM
Experienced Mechanic
Sounds like the fuel pump is failing. Here is a guide that will help get us started:
https://youtu.be/dCjmRL3p4Cs
I would suggest we start with checking the fuel pressure using the guide below.
I attached the spec below for you to compare your vehicle too.
Let us know what you find. Thanks
Image (Click to enlarge)
Mar 9, 2021 at 9:41 AM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
