Car that has recently broken down stalling while idling
150,000 MILES • MANUAL
JOSHUA PECKMAN
Hi! My car broke down earlier this summer on the interstate. The engine was smoking, and the steering locked so my dad and I had to put it in neutral and push it to safety, and get it towed. The serpentine belt had given out, and in the shop they also replaced the A/C compression and vacuum. They said it was safe to drive, but in the last month it has stalled while idle on 3 separate occasions. Each time has been within the first few minutes of driving, at a red light or stop sign. The engine stops, so I turn the ignition to off, back on, and then continue without further problems for weeks. Other than this, the car has been driving smoothly since the work in the shop two or so months ago, including making more than one longer drivers (between 2 and 5 hours). What could be malfunctioning? Could it be related to the problems from earlier in the summer, or something different entirely? Are there any particular warning signs I should be looking for for a proper diagnosis?
Aug 21, 2019 at 8:18 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Has the check engine light ever stayed on while the engine was running? If it has, then first you need to retrieve diagnostic trouble codes. You will need a scanner to do it. Here is a quick video showing how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times a parts store will check codes for you free of charge. Or, they may rent/lend you a scanner.
Now, if the light isn't on, it could be a number of things. Areas that include things such as fuel pressure, engine vacuum, ignition, idle speed control and so on can all cause an engine to stall.
Here are two links for you to look through. When you get a chance, read them and see if anything seems to mirror what you are experiencing. If you find something that seems to fit, let me know and I will help you diagnose and repair the problem.
https://www.2carpros.com/articles/stall-at-idle
https://www.2carpros.com/articles/engine-stalls
Aug 21, 2019 at 12:21 PM
