engine overheats
200,000 MILES • 4 CYL • AUTOMATIC
BRAINSAM
  • 8 POSTS
My car temperature get close to the highest and eventually goes back to the middle and eventually climbs and fall.. It is never stable. What could be responsible?
Jan 15, 2017 at 6:15 AM
SATURNTECH9
  • 30,869 POSTS
Does the car ever overheat? Is your radiator fan coming on about half way on the temperature gauge?
Jan 15, 2017 at 6:50 AM
JOHNNY G.JR
  • 320 POSTS
Check level of coolant first in radiator and reservoir.
Jan 15, 2017 at 9:32 AM
BRAINSAM
  • 8 POSTS
It was and i was told the water pump and radiator top was bad, so i replaced both was bad.. One liter of coolant was added recently. One of the fan stopped working and i got a replacement.
Jan 15, 2017 at 1:43 PM
BRAINSAM
  • 8 POSTS
I do not put water nor coolant in the return/reservoir.
Jan 15, 2017 at 1:45 PM
JOHNNY G.JR
  • 320 POSTS
Is any white smoke coming out of tailpipe "steam" upon startup?
Jan 15, 2017 at 2:06 PM
SATURNTECH9
  • 30,869 POSTS
When you added coolant did you use the bleeder screw with the car off and bleeder screw open. Where you added coolant until the bleeder screw had a steady stream coming out of the bleeder screw and then you closed the bleeder screw. then finished filling the radiator. Then topped off the coolant over flow tank? Also, are both radiator fans working now? Are the radiator fans coming on at about half way on the temperature gauge?
Jan 15, 2017 at 2:38 PM
SATURNTECH9
  • 30,869 POSTS
Also, make sure the engine is cold when you have the coolant bleeder screw open.
Jan 15, 2017 at 11:06 PM
BRAINSAM
  • 8 POSTS
I will do that and get back.. Thanks so much..
Jan 17, 2017 at 3:01 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome keep us posted on how it goes.
Jan 17, 2017 at 3:05 AM
BRAINSAM
  • 8 POSTS
Enter reply...should i also add water and coolant into the return tank /resavoir?
Jan 17, 2017 at 3:06 AM
SATURNTECH9
  • 30,869 POSTS
Yes get 50/50 coolant and fill the over flow tank up as well.
Jan 17, 2017 at 3:09 AM
BRAINSAM
  • 8 POSTS
Should i add coolant to the overflow tank as well boss?
Jan 17, 2017 at 3:20 AM
SATURNTECH9
  • 30,869 POSTS
Yes fill the whole system the radiator and the overflow.
Jan 17, 2017 at 3:36 AM
SATURNTECH9
  • 30,869 POSTS
Use the bleeder screw to help get the air out.Also are both radiator fans working now?
BRAINSAM
  • 8 POSTS
They are working boss..
Jan 17, 2017 at 4:02 AM
SATURNTECH9
  • 30,869 POSTS
OK let me know how it goes after you use the bleeder screw and all that
Jan 17, 2017 at 4:13 AM
BRAINSAM
  • 8 POSTS
Good morning boss.. I did what you requested of me.. And still no avail.. I personally watched to observe the processes but still d temperature get higher.. Almost d the red n almost never returned.. Kindly advise
Jan 20, 2017 at 5:57 PM
  • 55,743 POSTS
Can you use an infrared temperature meter on it to see if what temp it is running?
Here is a guide to help.
https://www.2carpros.com/articles/how-to-use-an-infrared-temperature-meter
Please let us know what happens so it will help others
Best, Ken
Jan 23, 2017 at 8:38 PM
