Vehicle is running cold, A/C hot and engine light on
85,000 MILES • 1.3L • V6 • 2WD • AUTOMATIC
GRACEGAUL
The A/C was having cooling issues. I replaced the evaporator temperature sensor as well as the cabin filter. Now the vehicle is still running cold, A/C hot and engine light on. Please help.
May 8, 2021 at 1:20 AM
Sounds like we may have two different issues. I doubt A/C being hot is causing the engine to run cold.
When you say it is running cold, what is the temperature that it is running?
Also, we need to check the codes and find out what are there.
Then we need to check the pressures of the A/C system but I suspect we are going to have to start a new post for that issue as I doubt it is related.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Let's start with the check engine light and then figure out what the actual engine temperature is and we can go from there.
Thanks
May 9, 2021 at 3:04 AM
