Car takes a while to do into D.
168,745 MILES • 0.5L • V6 • 4WD • AUTOMATIC
NENEK
When I'm putting my car into D it won't do . Most times it takes a second to go into D other times it takes a while . I was told to get my transmission service ,but a flush will mess up the car . I told to get some Seafoam Transmission Addctive . I don't know what to do . I don't want to mess up my car. What should I do ? Please help.
Aug 26, 2016 at 2:42 PM
HMAC300
  • 48,601 POSTS
the trans fluid must be Nissan only, of if its low put it back to full but check when transmission is warm so drive at least 10-15 miles.
Aug 26, 2016 at 11:16 PM
NENEK
The car wrong transmission fluid was drained and replaced with the right transmission fluid. Seafoam transmission additive was added too. Will this fix the problem ?
Aug 27, 2016 at 12:09 AM
HMAC300
  • 48,601 POSTS
it should but if you already did it then see what happens.
Aug 27, 2016 at 2:02 AM
