Takes a little longer to start after sitting thirty minutes
74,300 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RYANS79
Hi, my car starts right away in the morning or when engine is cold. It will also starts instantly after a five minutes sitting when warm. Will also starts instantly when turning off the engine and starting it back again immediately.
But if I try to start it let say after around thirty to forty five minutes when it has been sitting after driving (engine still l warm) it will crank a little more than usual before firing up.
Any conclusion out there please?
Thanks.
Dec 17, 2018 at 7:40 AM
  • 110,248 POSTS
Honestly, if it isn't excessive, it may be normal. Often times, the engine coolant temperature sensor may be telling the computer it's warmer than it actually is. The result is a leaner fuel mixture which may cause a slightly longer crank time.
If it is excessive, let me know.
JOe
Dec 18, 2018 at 10:55 AM
RYANS79
Can it be the MAP sensor too ? I will remove the MAP sensor see if I can clean it. I will also try to turn the key on but without starting the engine and switch off and on second time turn it to start and fire the engine and see what it does. I will let you know ASAP.
Dec 18, 2018 at 11:05 AM
  • 110,248 POSTS
Welcome back:
Sounds like a plan. The second idea you mention sounds like you are checking for fuel pressure drop off. I don't think that is the problem since it starts cold.
Let me know what you find.
Dec 18, 2018 at 12:40 PM
