car take long to start when cold
114,111 MILES • 1.6L • 6 CYL • 4WD • AUTOMATIC
CEDRIC WILLIAMSON
after the car is parked for a long time it take long to start
Feb 9, 2014 at 1:37 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
theres probably a fuel check valve in the pump assembly that's leaking down over time. try keying it on without starting several times to prime it next time to check this. sometimes these valves are serviceable separately and sometimes you have to replace the whole pump. you should also replace the fuel filter if its been a while
Feb 9, 2014 at 6:55 AM
