Shuts off while driving
240,000 MILES • V8 • 4WD • AUTOMATIC
MPHO MONAKALI
I bought the vehicle listed above three weeks ago, On Saturday while I was driving on the main road the vehicle switches itself off everything was lock luckily I was approaching a robot. I tried to start the car but it didn't start gauges were on and the was a security key display that was not going off after 15 minute the car started , I drove for about 10 minutes and it stopped again, I was so scared with my wife and my 5 months old baby as the car doesn't notice and uncontrollable when it stopped, it does that 4 times before I reached home. yesterday I took it to a mechanic minutes from my place . he put his machine in the car but he couldn't diagnose the problem, it did the same thing 3 while the mechanic was test-driving it, I'm worried that next me I wont be so lucky when it does that on the road. Please advise how can I sort out this problem. Regard, Sydney
Jul 21, 2019 at 5:24 PM
Good morning,
You need a different technician. Scan tools will not tell you the issue, good old fashion diagnostics will tell you the issue.
https://www.2carpros.com/articles/engine-stalls
I would start by having the fuel pressure tested as it could be a failing fuel pump. It locks up when hot and releases after it cools off.
Also, the spark is a concern. When the car shuts off, they need to see if the spark is present.
Once they determine the area of failure, it will be easy to determine the exact failure.
Jul 21, 2019 at 9:54 PM
