Car surges when A/C is on
140,000 MILES • 4 CYL • 2WD • MANUAL
JOE DERRETT
  • 7 POSTS
If I turn my A/C on my car surges. I've replace injectors MAF sensor, throttle position sensor, computer, fuel filter, checked vacuum leaks and complete A/C system. still surges and 7 km per liter. what am I missing?
Aug 7, 2019 at 10:20 PM
Good morning,
Are there any codes?
If you have an EGR valve not seating, it could do this issue.
https://www.2carpros.com/articles/engine-surges
Aug 7, 2019 at 10:55 PM
JOE DERRETT
  • 7 POSTS
My car has no EGR valve so mechanic suggested new fuel pump. so I had him replace that. still surging I'm really getting frustrated now.
Aug 20, 2019 at 1:17 AM
The fuel pump will not do this.
I would think that the injectors may be varnished up. Additives have no effect on the cleaning out of the varnish.
You need to have someone disable the fuel system and hook up a gauge and use cleaner directly into the fuel rail and run the engine on it until the can is empty. Then see if it still does it.
roy
Aug 20, 2019 at 1:55 AM
JOE DERRETT
  • 7 POSTS
Injectors are brand new.
Aug 20, 2019 at 1:36 PM
What else have you done.
Aug 20, 2019 at 2:05 PM
JOE DERRETT
  • 7 POSTS
Injectors,fuel pump, MAF sensor ,throttle position sensor, comp , plugs ,wires,cap ,rotor all new gadgets ,fuel filter.
Aug 20, 2019 at 7:46 PM
JOE DERRETT
  • 7 POSTS
Injectors,fuel pump, MAF sensor ,throttle position sensor, comp , plugs ,wires,cap ,rotor all new gadgets ,fuel filter and checked for vacuum leaks.
Aug 20, 2019 at 7:48 PM
You either have a vacuum leak or possibly the catalytic converter may have a restriction.
A lot of parts with no result.
Aug 21, 2019 at 4:58 AM
JOE DERRETT
  • 7 POSTS
Well it's fixed Roy. the IAC was carboned up so took throttle body off cleaned the IAC and all the carbon throughout the throttle body and it is now running perfect again .
Aug 21, 2019 at 10:31 PM
Good find.
Aug 21, 2019 at 11:25 PM
