Car suddenly removes sluggish burning smell on driver side front tire
2004 NISSAN QUEST
150,000 MILES • AUTOMATIC
PEREZ246
My van will drive fine and then after a while it will not go anymore above a couple miles per hour. The whole car shakes like I am pushing it to go and then the front left driver side smells like something's burning and if I keep going and actually has smoke coming out. Also, if I let go of the gas the car just stops it does not decelerate at all.
Mar 14, 2018 at 8:35 AM
Good evening.
It sounds like the left front brakes are not releasing and preventing the car from moving.
You need to check the brakes and see if that wheel is locking up.
Mar 14, 2018 at 8:47 AM
PEREZ246
Will do. Thanks.
Mar 14, 2018 at 8:53 AM
You are welcome.
check the brake hose and the caliper. they are common failures for this issue.
Mar 14, 2018 at 8:54 AM
