Car Stopped working
80,000 MILES • 4WD • AUTOMATIC
YOUSTINA
The car has stopped working. After it stopped working, we thought the problem was the fuel pump. so we changed the fuel pump but it still does not work or start up.
In fact before it has stopped working, the dashboard kept showing ESP signals.
Oct 11, 2016 at 6:08 AM
  • 55,711 POSTS
Those cars have a fuel control solenoid that shuts the fuel down, if that goes bad it will stop the fuel from getting to the engine, it is common that this valve goes bad. It is located near the top of the engine I believe.
Here is the part:
http://www.ecklersmbzparts.com/mercedes-shut-off-valve-diesel-engine.html
Please let us know what you find so it will help others.
Best, Ken
Oct 11, 2016 at 7:11 AM
YOUSTINA
Thanks what does fuel control senoid mean?
The car is run by petrol not diesel. The picture shows diesel.
Where does this car part suggested go in the car?
Oct 11, 2016 at 7:19 AM
  • 55,711 POSTS
240D is the model you selected which means diesel. Can you please double check the model again.
Oct 11, 2016 at 8:08 AM
YOUSTINA
Sorry it is C240.
Oct 11, 2016 at 1:57 PM
  • 55,711 POSTS
No worries, please scan the PCM for codes, it sounds like it could be a crankshaft angle sensor not supplying ignition or fuel trigger. Here are some guide to read through to help out.
and
and
and finally
Let me know what happens.
Best, Ken
Oct 11, 2016 at 3:15 PM
