car stopped
SHEHGAM
my car stopped after making a loud noise while i was driving it it will crank back up and will rev up but it wont move and the tires are locked as well. it has been making noises when i turn the wheel but i really need to know what wrong and how much it would coast normally to fix this problem
May 28, 2013 at 2:41 AM
CARADIODOC
  • 34,414 POSTS
You need someone to actually look at it to see what the problem is. A large pin may have come loose in the differential. That could cause the symptoms you described but there's many other things to check.
We don't get involved with costs here because there's way too many variables. We don't know if this problem has a simple cause, it needs a new transmission, what the labor rates are in your area, etc. We don't even know the engine size or whether it's an automatic or manual transmission. No idea if transmission fluid leakage is involved. We don't know what "stopped" means. Did the engine stall? Did the car stop because the brakes locked up?
May 28, 2013 at 3:02 AM
