Car starts then immediately stops?
160,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
KEBIRDIE
It's been driving absolutely fine, but today as i started it, it began to rev up and down. I turned the engine off and plugged in my OBD reader. I tried starting again, now the car will just about start then die immediately. No codes. I'm hoping this is just a battery issue. The current voltage from the battery reads 11.80. I'm going to try a jump start first, but is there anything else I should check?
Jun 4, 2023 at 4:24 AM
  • 55,770 POSTS
The battery voltage is low, which is what I would address first. Also, I would check the charging system.
Here is a guide to help us get started:
Also make sure the cables are clean and tight.
Here is a guide to help:
Here are guides to help you change out the battery and have it checked/replaced. If everything checks out, I would do a CAN scan which is different than a simple engine scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jun 5, 2023 at 4:37 AM
