Engine will not stay running?
61,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JUSTINWAUN
Car starts, then shuts off. The P,R,N,D,3,2,1 light flash and then the display reads "headlamps required" "theft system problem" "car may not restart" " service passenger airbag" I have no power windows, or locks. The keyless entry does not work. No power to the trunk release, or fuel door release buttons either.
Jan 15, 2023 at 8:33 AM
  • 55,658 POSTS
This sounds like the PCM is bad, but we should check the fuses first.
here is a guide to help and the fuse locations as well:
If the fuses are okay (test with ignition on) I have left the location and instructions on how to change out the PCM, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know what you find. We are interested to see what it is.
Jan 16, 2023 at 6:05 AM
JUSTINWAUN
The fuses are all good, I'm leaning more towards the BCM or IPC, since there are no issues with the power train, I don't know why I would need to change the PCM. The instrument panels have no power nor do the dome lights. And no power to the fuel and trunk doors, or windows or locks. This would definitely have to be the Body Control Module, or Instrument Panel Cluster, right?
Jan 16, 2023 at 7:10 AM
JUSTINWAUN
So, I tested all rear fuses with a new low voltage computer safe tester, I'm not getting any power to any of the rear fuses. I have continuity in them all, but the voltage tester shows no power. Key was on when testing. Is this BCM? Or maybe a bad ground?
Jan 16, 2023 at 8:45 AM
  • 55,658 POSTS
The rear fuse panel gets its power from the front fuse block (body1 and body2 fuses) they are under the hood. Check out the images (below). Please let us know what happens.
Jan 17, 2023 at 6:38 AM
JUSTINWAUN
Changed both 60-amp fuses even though they tested fine. Update however, I pulled the interior shroud under the driver dash and see a ton of water drops due to moisture all over the wiring and plugs located way up behind the instrument panel... I used some shop rags to dab the water drops and hung 2 "Damp rid" bags. 1 under the dash where I removed the shroud, and 1 from the rear view mirror. I will let the sit until Friday. Which is 2 days from today. Then I will put some heat in there for a bit, clean the plugs, and see if It helps. There was no moisture in the trunk. I will post an update Friday night.
Jan 17, 2023 at 7:53 AM
  • 55,658 POSTS
Good job, it sounds like you may have a leaking windshield. Let me know what happens.
Jan 18, 2023 at 2:22 AM
