Car starts RPMs fluctuating then stalls?
143,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
XZAVIORSANTOS
My heater hose had a hole and was spewing coolant i drove it home with no problems or overheating. I took the heater hose off and replaced it the upper radiator hose was in the way. so, I unplugged it from the engine had no coolant in the reservoir. so, I filled it up and now it will start but the RPMs go crazy and then the car shuts off.
Jul 22, 2023 at 6:49 AM
  • 110,248 POSTS
Is the check engine light staying on when the engine does run? If it is, you need to scan the computer for diagnostic trouble codes. Here is a link that shows how it's done:
Also, make sure no engine vacuum hoses were damaged or disconnected.
Let me know what you find.
Jul 22, 2023 at 3:32 PM
XZAVIORSANTOS
So, I’m pretty sure the hose I disconnected was the vacuum hose and not.
Jul 22, 2023 at 10:33 PM
  • 110,248 POSTS
Were you able to reinstall the hose? Did it make any difference?
Let me know,
Jul 23, 2023 at 11:28 AM
XZAVIORSANTOS
I reinstalled the hose and I just changed the CPS and now it stays running but the idle is still rough.
Jul 23, 2023 at 1:46 PM
  • 110,248 POSTS
You may have another vacuum leak. They usually cause a rough idle or even stalling. Take a look at this link and try what it explains to do:
Jul 24, 2023 at 1:19 PM
