Car starts for two to three seconds then stalls
110,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
VINNIEVALENS
Changed out ignition switch, pass-lock sensor, still won't start. Noticed that gas gauge was at 1/4 tank then drops to or below the E while key is on. Will return to 1/4 tank after a few second's then back to E. Any ideas would help.
Dec 7, 2019 at 6:20 AM
  • 55,649 POSTS
When you crank the engine over to start the engine does the security light flash? If so this guide will help reset it:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 8, 2019 at 9:48 AM
VINNIEVALENS
Sorry, tried all the resets and still won't start. Security light is on and not flashing. Engine runs for a few seconds and stops.
Dec 13, 2019 at 12:48 PM
  • 55,649 POSTS
When the engine stalls, turn the key off then to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Dec 16, 2019 at 3:08 AM
VINNIEVALENS
Yes, checked fuel lines and wiring. Fuel pump works and there's gas running to the engine (pressed bleeder valve and strong pressured gas shot out).
Dec 16, 2019 at 2:03 PM
  • 55,649 POSTS
Okay cool, now when the engine stops running can we check for spark? Here is a guide to help us:
Dec 17, 2019 at 3:53 AM
VINNIEVALENS
Hello, checked ignition coils and installed new spark plugs (needed new ones anyway, been 8 months since I last changed them). Tried 30 minute reset to make sure it isn't security. On last 10, I turned on key. I didn't start it but noticed that security light and service vehicle soon came on. Security light is not flashing, but just on. Any ideas?
Dec 20, 2019 at 11:42 AM
  • 55,649 POSTS
Do you have spark when the engine is cranking over? Check out the guide for the test.
Dec 21, 2019 at 3:29 AM
