Car starting issue
76,000 MILES
DABLU MAHATO
My battery is new. When I am going start the car, cranking is happening but car is not started.
Jul 13, 2020 at 5:29 AM
4DRTOM
  • 467 POSTS
I can give you a hand we will need to figure out if its a fuel or ignition problem. Do you hear the fuel pump turn on when you put the key in the on position? It should turn on for 3-5 seconds.
Here is an article relating to a dead or battery change then it not running it may help too:
https://www.2carpros.com/articles/engine-stalls-idles-too-high-low-after-dead-or-replaced-battery
Let me know if you hear the pump.
Tom
Jul 13, 2020 at 8:28 AM
