My battery is new. When I am going start the car, cranking is happening but car is not started.
Jul 13, 2020 at 5:29 AM
4DRTOM
✓Experienced Mechanic
I can give you a hand we will need to figure out if its a fuel or ignition problem. Do you hear the fuel pump turn on when you put the key in the on position? It should turn on for 3-5 seconds.
Here is an article relating to a dead or battery change then it not running it may help too:
