Car not starting?
190,000 MILES • 3.8L • 6 CYL • TURBO • 2WD • AUTOMATIC
SMACK6969
Car will not start turn the key and all the gauges go all the way up and lights go out.
Jul 28, 2022 at 10:33 AM
  • 110,248 POSTS
Do you mean all the lights go out when you try starting it? If that is the case, you could have a weak battery, or a very common cause is a loose or corroded battery cable.
Take a look through this link. It explains how to load test the battery at home. No tools are needed.
If the battery passes that test, check the terminals.
Here is a link that you may find of interest and helpful:
Let me know what you find. If I misunderstood what you meant, let me know exactly what is happening.
Jul 28, 2022 at 3:02 PM
