I have been having problems with my car stalling at idle when it is cold, and you people have been so kind to give me your best suggestions on what might be going on. I finally took it to the repair shop and had a test done on it to see if the head gasket was leaking and they told me the water pump is fine and the head gasket is fine, but the radiator is half plugged as the temperature at the top and the bottom of the radiator was totally different along the the bottom hose being cold.
My question is, would that cause the car to continue to stall when it is cold and when it is at idle? The only thing the mechanic could think of as well as myself, I used to be a mechanic a while back, was that the computer is not reading correctly as the engine is not getting up to the correct temperature as there was no light on in the dash. Other than that I am open to suggestions on what might be going on with the stalling problem. I am also experiencing no heat when I turn my heater on, which just started as well.
I will be swapping out the radiator this weekend. If you have any other ideas of what might be causing the stalling please let me know.
Thanks
Thanks
Apr 2, 2018 at 9:31 PM
