I bought the car a few weeks ago
ran and drove great no problems at all except slight shifting slippage between 2nd and 3rd gears up hills.
stopped at a jiffy lube for an oil change
drove about 1.5 miles and the car died. acted like I was out of gas. would not restart. turns over but like it has no gas
assuming my problem was a faulty gas guage that read 1/4 tank I walked over to the gas station and bought a few gals gas and a can of starting fluid. put in the gas tried to start, still like it has no gas, added starting fluid to carb and it started right up, filled up the gas tank and drove home making many stops along the way, all was ok.
next day drove to town all was fine til mid afternoon it died again in much the same way, but this time we knew it had a full tank of gas. replaced the fuel filter. noticed the fuel pump was missing a bolt. but the car started after the filter replacement with a quick prime and drove til the next time it was turned off then only made it 1/2 block before dying. waited for help about an hour with more starting fluid and started it up and drove it home. next morning drove to town to get fuel pump and bolt. drove home and replaced fuel pump.
this did not help.
it is not consistent when it will die. always starts fine in morning, and can usually drive to town without problems. town in 15 miles. sometimes will have no problems all day sometimes it will die after long drives 30+ miles sometimes it will die within half block or so after restarting from a quick stop. does not always restart with starter fluid right away. sometimes have to wait an hour or so then will start with fluid. never restarts no matter how long we wait without starter fluid.
please help.
this did not help.
please help.
Jul 10, 2014 at 5:49 AM
