Car stalls every six weeks?
80,000 MILES • 2WD • AUTOMATIC
RENEE LOUISE
I have the car listed above that runs well except for about every 6 weeks it will stall out. It's always when I'm at a long red light. It starts up again right away, and then there's no problem again for the following 6 weeks. I took it to a mechanic who couldn't find thing wrong with it. Any ideas?
Nov 16, 2022 at 6:08 AM
  • 55,732 POSTS
This can happen if your engine has a vacuum leak, or the throttle actuator needs to be serviced. Also, did the mechanic run the codes? If not, we should do that as well.
Here are guides that can help us fix the car. Please go over them and get back to me.
https://www.2carpros.com/articles/stall-at-idle
and use this guide when the engine is cold only.
and
and
Check out the images (below). Please let us know what you find. We are interested to see what it is.
Nov 17, 2022 at 3:06 AM
