car stalls at 3000 rpm , with check engine light
57,000 MILES
RASHIDKHAN
had fueled up on a highway , after driving for around 3 kms the car stopped , didnt start again after all attempts , then started after 8 hrs , when i checked with a local mechanic he reasoned out adultrated fuel , got the diesel tank cleaned , changed the fuel filter , afterwards the car used to turn OFF while driving and car stalls the moment it reaches 3000 rpm .
Got the car checked at hyundai service station , but still no solution
Please HELP
Sep 16, 2013 at 11:39 PM
KHLOW2008
  • 41,812 POSTS
What trouble codes was shown by the Check Engine Light indicating?
Sep 17, 2013 at 12:56 AM
RASHIDKHAN
the diagnosis says " fuel rail pressure low " , got the pressure sensor replaced , now the mechanic has repaired the fuel pump , he said the car is running fine , but the check engine light is back again , the car is still in garage in other city , so couldnt check myself
Sep 17, 2013 at 7:28 AM
KHLOW2008
  • 41,812 POSTS
Get the code and we shall see what needs to be done.
Sep 17, 2013 at 11:37 PM
RASHIDKHAN
Sorry for the delay , The error code is P1186 . and would like to share more
1) Takes 4-5 secs to start
2) when accelerating in 1st or 2nd gear , some times the RPM does not go beyond 3000 RPM - with check engine light, when i switch off the car and again start it accelerates beyond 3000 rpm
3) engine stops while driving , again starts
BUT all these above problems does not show when the fuel tank is full , and runs without any problem for approx 300 kms without the check engine light , then back with the above 3 problems .
have visited some diagnostic centres and company service centre , no one is sure what has to be changed ,
some of the recceomedations from the mechanic
1) weak high pressure fuel pump
2) accelerater paddle sensor
3) common rail
4) pressure sensor on common rail
Please Help
Oct 28, 2013 at 7:23 AM
KHLOW2008
  • 41,812 POSTS
Since problem is affected by fuel tank level, have the fuel tank and EVAP system checked.
Oct 28, 2013 at 10:26 PM
RASHIDKHAN
Thank you very much for the solution , got the fuel sender changed (unit fixed on the diesel tank ) , and the problem is solved .
Thank you very much
Nov 18, 2013 at 3:30 AM
KHLOW2008
  • 41,812 POSTS
You're welcome.
Nov 19, 2013 at 2:53 AM
RASHADBARAMY
Hi Rashid Khan,
Could you be more specific on what parts you changed.
I have a similar issue on my Dodge Durango. The Engine Lights turns on when the fuel is less than half tank and engine stalls above 3000 rpm.
Thanks in advance.
Feb 16, 2016 at 6:43 PM
KHLOW2008
  • 41,812 POSTS
That should be the fuel sending unit, the part that is on top of the fuel tank whereby fuel is delivered from tank to the fuel filter in front.
Jul 7, 2016 at 2:52 PM
