Car stalls
300,000 MILES • 1.0L • 4 CYL • FWD • AUTOMATIC
ROSE GRAY
Stalls when I apply brakes and go to stop or first crank up.
Oct 10, 2017 at 9:17 AM
  • 31,937 POSTS
You may have a leaking brake vacuum booster. remove the hose from the booster and plug, start the engine and apply the brakes, (the brakes will feel very hard this is normal with the booster disconnected) if the engine revs do not alter or stall, the booster will be leaking. Do not drive with booster disconnected as you will have very poor brakes. this is a static test only.
Oct 10, 2017 at 10:54 AM
