Car stalling while driving
242,000 MILES • V8 • 4WD • AUTOMATIC
MPHO MONAKALI
My vehicle listed above switches itself off while I'm driving. it wont start when I'm trying to start. it will only start after about 20 minutes some times will start after an hour.
Sep 30, 2019 at 2:52 PM
This sounds like a couple things. First and most likely is the crank sensor. Here is a guide that gives more detail:
The next possible cause is the PCM. However, here is another guide that we need to review before we just replace the PCM:
https://www.2carpros.com/articles/engine-stalls
I am going to assume you have no codes but we need to check. No codes and this happening points again to the crank sensor.
Please let me know if you have questions after you review this material and if you have already performed any repairs to attempt to repair this and we can go from there.
Oct 1, 2019 at 9:17 AM
MPHO MONAKALI
Morning, thank you for the information. I did send it to a mechanic, it gave me 2 error codes; 1495 and 1391. please advise on these error codes.
Oct 1, 2019 at 5:29 PM
Attached are the details about these codes. Your stalling issue is most likely related to the P1391. The other code is just an emission code and while it should be addressed, it is not going to cause a stall issue.
Run through the test for the P1391 and let me know what you find. Let me know if you have more questions. Thanks
Oct 2, 2019 at 12:25 PM
