Car stalling, then starts back up?
240,000 MILES • 4 CYL • 2WD • AUTOMATIC
OLIER
Car has stalled twice while going slow (turning at an intersection?.
Jan 30, 2023 at 11:22 PM
  • 55,688 POSTS
This is common when the throttle bore is dirty and needs service or you have a vacuum leak. Here are guides to help us fix it with instructions in the images below to show you how on your car:
Please use this guide when the engine is cold only:
This guide can help as well:
https://www.2carpros.com/articles/stall-at-idle
Jan 31, 2023 at 2:51 AM
OLIER
Thank you! I'll pass this info on to my mechanic. He couldn't find anything wrong. Also, I noticed that the clock time went arry- could an electrical problem be present also?
Feb 1, 2023 at 10:12 PM
  • 55,688 POSTS
This happens when the battery has disconnected for a short period, can you please check the battery cable connections, this can cause the stalling issue as well.
Here is a guide to help:
Please go over this guide and report back.
Feb 2, 2023 at 5:54 AM
