CAR STALLS WHEN SLOWING DOWN OR WAITING AT A STOP LIGHT
194,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JGONZALEZESTRADA
I have an Eclipse GS and I cannot seem to find the problem for why the car suddenly stalls. The car has a new fuel pump, crankshaft and camshaft sensor, and an EGR valve and circuit. The IAC valve has been cleaned. I cannot figure out what is causing the problem. The car will drive fine some days, but other days I will be slowing down to park and the car stalls or the car stalls while waiting at a stop light. Help please.
Oct 26, 2016 at 11:56 AM
HMAC300
  • 48,601 POSTS
clean throttle plate on both sides and IAC not just IAC. then scan for codes if any.
Oct 26, 2016 at 11:09 PM
JGONZALEZESTRADA
The throttle body plate was cleaned as well.
Oct 27, 2016 at 4:50 AM
JGONZALEZESTRADA
Also, the car shows no codes.
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge you may need an adapter though autoparts rent it. see link.
Oct 27, 2016 at 5:00 AM
