The engine sputters on cold morning starts and loses power when accelerating?
160,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
TRUONG VU
  • 14 POSTS
My car sputters in cold morning start and loses power when accelerating even if I floor it. I have to release the gas pedal and press again. I notice it happens more in winter time than in summertime. No engine code at all. I just had the tune up, new spark plugs, new leads. Can you tell me what should I replace or check?
Apr 25, 2023 at 2:15 AM
  • 110,248 POSTS
Since it happens when cold, the first thing I would suggest is to check the signal from the coolant temperature sensor. This sensor provides information to the powertrain control module that is used to determine the correct air/fuel mixture to run the engine based on outside temperature.
If you have a live data scan tool, check what it is indicating before starting the engine for the day.
Also, has fuel pressure been tested or the exhaust for a partially plugged catalytic converter? If not, those are two other areas that can cause what you described.
Here are two links that you may find helpful:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Apr 25, 2023 at 12:42 PM
