Car speaker have stopped working
60,000 MILES
AYUSHVYA
Only one side works and when drivers side is connected messes up the other one as well.
Jan 9, 2020 at 6:30 PM
  • 110,246 POSTS
If you lose both sides when you reconnect the driver's side, there must be a short. I have to be honest, this vehicle isn't offered in the US, but I'll give it my best shot.
Is this a factory equipped system or is it aftermarket? How are you disconnecting one side at a time or are you disconnecting it at the speaker?
Jan 11, 2020 at 2:28 PM
AYUSHVYA
The head unit is after market but the speakers are stock, head unit works perfectly fine. I remove the door trim and disconnect the wires from the back of the speaker.
Jan 12, 2020 at 6:04 AM
  • 110,246 POSTS
Something is shorting that side. Don't connect it until it's found. You could damage the unit. Do me a favor, and this is going to sound crazy. Disconnect the speakers that are not working. Connect two wires to the connections on the speakers. Next, take a double A battery or a 9 volt and while holding one wire on the battery -- . take the other wire and tap it on and off the battery +. If the speaker is good, you will hear it respond to the battery power. It should make a clicking sound. If it doesn't, the speaker is shorted internally and needs replaced.
I realize this sounds archaic, but it is a simple way to determine if a speaker is blown.
Let me know what you find.
Jan 12, 2020 at 9:03 AM
