The engine sounds like it is revving high after having the oil changed?
150,000 MILES • V6 • 4WD • AUTOMATIC
CRISSY85
I took my car to get a simple oil change, and now it sounds like it's revving high, kind of reminds me of an airplane. My tire sensors are working, and I feel like they did something to my car. Please help.
Jul 24, 2023 at 10:18 PM
  • 110,248 POSTS
There is a chance a vacuum leak is present. A hose may have been disconnected or damaged when the work was being done.
How high is the engine idling? If it has a tachometer, at what RPM does it idle?
If you want, open the hood and check for disconnected vacuum hoses and make sure the air filter box and air inlet tube is fully attached.
Jul 25, 2023 at 2:20 PM
CRISSY85
The RPMS are normal it just sounds like it is.
Jul 25, 2023 at 8:44 PM
  • 110,248 POSTS
Make sure nothing with the air intake tube from the air filter was left disconnected. Also, if you could, record it and upload it for me to hear. I may recognize the problem.
Jul 26, 2023 at 12:42 PM
