Car smells disgusting, how do I fix it?
80,828 MILES
FABIAN CHARLTON
  • 53 POSTS
The car has not driven for a long time, like 2 years. It was store outside. I live in NYC.
The A/C is not working due to some leak somewhere while it wasn't used, I'll probably fix next summer.
I do not like switching to outside air because it smells disgusting for some reason like it isn't getting air from the outside. Recycled air smells good because it's using the inside air which has fragrance.
The cabin air filter was changed and the filter by the engine that connects to the MAF.
What can I do to fix it?
Oct 27, 2022 at 1:07 PM
JIS001
  • 3,412 POSTS
It is very difficult to diagnose smells without actually getting a clear description. I have smelled some pretty bad ones before. I had a customer leave salmon under the back seat and that really was disgusting. Sometimes rodents will crawl inside the cabin and build nests as well. They sometimes die inside, and the stench is unbearable.
One way to check for rodents is to remove the cabin filter or if you remember from the last cabin filter change if there were droppings or maybe they were chewing at the filter? If you have a water leak inside because the A/C drain hose has a spider nest inside can also cause it to smell if it has been leaking for a while or water got inside.
If that is the case, you could have mold. For that you would need to contact a mold remediation company.
That job is very expensive, and I have seen insurance companies just do a total loss on a vehicle because the repair is so expensive. My advice would be to have it looked at by a repair shop to find the root cause of the odor.
I have attached a picture of a vehicle that had mold. We had to scrape the insulation after stripping the interior down. Very big job. Very expensive. After the mold treatment we had to install new insulation and replaced lots of parts.
Oct 27, 2022 at 1:30 PM
FABIAN CHARLTON
  • 53 POSTS
Well, I'm sure rodents were in the car for sure. But I haven't used the A/C ever, it's broken. So, the water drain wouldn't have water?
But I'll check it. Any diagrams?
I think that I may have to do something like this: https://youtu.be/o_SHGk6Gytk
Oct 27, 2022 at 1:34 PM
JIS001
  • 3,412 POSTS
I had updated my original post because I forgot to upload a picture of a vehicle we took apart.
Oct 27, 2022 at 1:45 PM
FABIAN CHARLTON
  • 53 POSTS
Question. I notice the smell when I use Max A/C, but now that the winter came I stopped using it anyways.
But I had fresh air intake without using max air and I noticed no bad smell.
But I then use the front window defroster which activated some additional mechanic because I smell it again.
Dec 17, 2022 at 7:32 AM
  • 55,746 POSTS
This smell can be caused by a leaking or seeping heater core, can you please check the passenger's side floorboard to see if there is coolant present? If so, you have found the problem.
Dec 20, 2022 at 2:41 AM
