Engine will not stay running
198,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MAGSENTONE
  • 85 POSTS
Hello, my starts up right away and sounds solid and then after idling for about 10 minutes or so it just shuts off or when coming to a stop. I had a mobile mechanic check the fuel pressure and he got a spec reading of 50 PSI all the way up to the fuel rail. I have no engine or DTC codes showing. Any valuable info would be greatly appreciated before I take it to the shop. Thank you
Feb 11, 2022 at 4:06 PM
  • 110,248 POSTS
Was the fuel pressure tested when the engine would stall? If it was and it appeared good, then it sounds like you are losing the ignition spark. Does it start right back up after it stalls?
Do me a favor. Take a look through this link and let me know if anything seems to mirror what you experience. I have a feeling the crankshaft position sensor may be failing. When they start to fail, they are affected by heat.
Feb 12, 2022 at 1:45 PM
MAGSENTONE
  • 85 POSTS
i believe you are correct. and yes, the fuel pressure was tested after it stalled, and fuel pressure was the same at 50 PSI (spec reading for my vehicle) and once it shuts off at idle you have to wait for the car to cool down before it will start again. My suspicion was telling the same as to it being the Crankshaft position sensor.
Feb 13, 2022 at 1:52 AM
  • 110,248 POSTS
If that is the case, this would be my first suspect. I attached a very basic pic below showing the directions and location of the sensor. Fortunately, it's an easy one to replace. It should be above the oil filter on the side of the engine.
Also, here is a link that shows in general how it's done:
I hope this helps. Let me know if it takes care of the problem.
See pic below.
Feb 13, 2022 at 6:42 AM
MAGSENTONE
  • 85 POSTS
thank you sir, I will let you know.
Feb 13, 2022 at 1:38 PM
MAGSENTONE
  • 85 POSTS
Hello there guys. so, i removed the tire to access the crank sensor and it was difficult to reach so much so that I couldn't remove the plug connector, so I just had it taken to the shop down the hill from my house. Also, just when I pulled it into the shop the check engine light finally came on. So, after they made repairs, he never really told me it was the crank sensor, but he did change the Throttle position sensor and the wiring pigtail I already placed before. Now the car starts right up and never stalls, however the check engine line came back on after driving it about 30 miles once cleared with the scanner. I did some troubleshooting myself and found that the primary resistance is off, specs call for 0.5 to .06 ohms and I am getting 4 ohms on each side of the middle connector terminal. the secondary terminals where the spark plug wires connect to check out perfect and are within specs which is about 12,760 ohms. Maybe I need to replace the coil? The book says I need to if either the primary or secondary readings are not according to specs listed. plugs check out great like new and I changed the spark plug wires today. I just wanted to give an update and see what you guys think.
Feb 21, 2022 at 10:01 AM
  • 110,248 POSTS
It sounds like the primary is bad. Did you have the computer scanned again after the check engine light turned on?
Let me know. If you have, let me know what codes turned up.
Feb 21, 2022 at 12:11 PM
MAGSENTONE
  • 85 POSTS
it was a P0300 random misfire.
Feb 21, 2022 at 1:26 PM
  • 110,248 POSTS
That makes sense. If the readings were that far off and it was a P0300, I would replace the coil. It appears to be the most likely cause.
Let me know if that takes care of the issue.
Feb 22, 2022 at 10:17 AM
