Shuts off while driving?
130,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CHRIS4456
My car shutoff while driving but it started backup after a few minutes and had to turn the air off if I turn on the air it shuts off, I scanned the car but no codes.
Jan 3, 2023 at 9:39 PM
  • 55,721 POSTS
This sounds like the fuel pump or crankshaft angle sensor is bad, when the engine stalls can you turn the key off, then back on again to see if you hear the fuel pump in the tank run for about 5 seconds? If not, I would change the fuel pump out.
Here is a video to help:
https://youtu.be/D1AyqeftAmA
Here is how to change the crankshaft sensor out if you hear the fuel pump run:
https://youtu.be/_xoGyRrHYbM
This guide can help as well:
https://www.2carpros.com/articles/engine-stalls
Check out the images (below). Please let us know what you find. We are interested to see what it is.
Jan 5, 2023 at 2:09 AM
