Car will start but it shuts off right away, will not stay running
2002 CADILLAC DEVILLE
94,000 MILES
RAMDG10
if i keep my foot on the gas it will stay running but when i take my foot off the gas it shuts off. someone told me its the IAC value could that be true?
May 25, 2013 at 1:35 AM
CADIEMAN
  • 3,544 POSTS
it could be lots of things. Sounds like the ideal speed control sensor. Take it to the parts store and have that codes check. You can start here.
May 25, 2013 at 2:00 AM
RAMDG10
is that the same as the Idle Air Control Value?
May 25, 2013 at 2:06 AM
CADIEMAN
  • 3,544 POSTS
yes that's only a shot in the dark. You need to have the code read.
Here is a link to help you if you decide to check the codes yourself:
May 25, 2013 at 10:29 AM
RAMDG10
Thank you very much. after talking to you i also Googled it and it told me how to test the part you told me about. and i found that it was stuck open. pick the part up for $200.00 and put it on myself. now my car runs fine. once again thank you!
May 26, 2013 at 11:40 AM
