car shut off while driving
2007 DODGE MAGNUM
122,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
IANPACLIN
i was driving and the car just shut off wont crank. i tried to jump it with my jump box and still wont crank. all my dash lights are working. got power to the car.
May 19, 2021 at 12:02 AM
When you say it will not crank, that means it will not even turn over when you are trying to start it correct? It is a term that gets confused a lot and people sometimes mean it will crank over but not actually start.
If the engine will not even crank over, do you hear a click or anything when trying to start the engine?
We need to try and turn the engine over by hand just to make sure it is not locked up. The fact that it shut off while driving and now will not turn over makes me concerned it is locked up so we need to put a wrench on the crank pulley bolt and make sure it turns over.
If it does then we need to follow this guide to take the next steps.:
Then we need to check the voltage at the starter while cranking and see what we have on both wires.
Below is the wiring diagram that will help with this as well. You should have 12 volts on both wires when cranking the engine.
Let me know what you find with this info and we can go from there. Thanks
May 20, 2021 at 11:47 AM
