Car shudders violently when driving 45 MPH once it is warm?
135,500 MILES • 6 CYL • 2WD • AUTOMATIC
KSIDD
The first time the check engine light came on and #3 ignition coil was changed. The problem continued. Transmission fluid change was suggested and done. Problem continues. The car also needs a new flex pipe. It was suggested that it was causing a backflow issue. Does this sound possible?
Jan 22, 2023 at 10:36 PM
  • 55,746 POSTS
This sounds more like a misfire problem; I would replace all spark plugs and the remainder of the ignition coils. Here is a generic guide to help you change out the spark plugs with instructions below to help you with your car:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Spark Plug .................... AGSF-32WM
You must remove the upper intake manifold which I have included as well. I would also service the throttle bore.
here is a guide to help you:
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Jan 23, 2023 at 3:09 AM
