Car shudders slightly when at rest or idling?
60,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RAPTUROS
  • 24 POSTS
I have noticed that when I am stopped at an intersection and am stepping on the brakes to keep the car from rolling forward, the car shudders slightly. Even when I release the brakes, the shudder continues just a bit before the car accelerates up to normal speed. When the car is moving forward no shudder is experienced.
May 13, 2024 at 7:09 PM
  • 55,781 POSTS
Does it feel like the engine is misfiring? can you please upload a short video of the problem so I can see? I want to get started on the right foot on not go down the wrong trail so I will need more information. Also, do you have a check engine light on?
Here are two guides I need you to go over so we can continue:
and
Please go over these guides and get back to us.
May 14, 2024 at 5:03 AM
RAPTUROS
  • 24 POSTS
No engine check light is illuminated but it does appear that an almost imperceptible hesitation occurs at random times as I accelerate. I did have the spark plugs replaced as this is a used car I purchased only a month or so ago. I also had the transmission fluid and brake fluid and power steering fluid replaced at the same time since I had no indication of the maintenance history of the vehicle.
May 15, 2024 at 8:54 AM
  • 55,781 POSTS
Okay, it sounds like you might have low compression one cylinder to be sure lets do a compression test, this guide can help.
Please upload pictures or videos in your response of any problems so we can see what to help you with.
May 16, 2024 at 4:40 AM
RAPTUROS
  • 24 POSTS
Aha. Turns out it was failing motor mounts. Once those were replaced the shudder disappeared. Thanks for your help.
May 16, 2024 at 3:09 PM
  • 55,781 POSTS
Yep, that is the disadvantage of not being with the car for me to see, thanks for letting us know, we are here to help, please use 2CarPros anytime.
May 17, 2024 at 2:32 AM
RAPTUROS
  • 24 POSTS
Okay, the shudder went away once the motor mounts were replaced. However, the second problem remains where when the wheel is turned all the way in one direction or the other the car begins to spin in that direction as if it had a life of its own, like it was caught in a whirlpool. This happens in reverse as well.
May 17, 2024 at 7:02 AM
RAPTUROS
  • 24 POSTS
Can you suggest any reason why the car spins severely when the car is going at very low speed like in a parking lot and the wheel is turned all the way to either the left or the right. This happens when going in reverse as well.
May 18, 2024 at 10:08 PM
  • 55,781 POSTS
Please start a new question and include a short video of the problem.
May 20, 2024 at 4:54 AM
