When stopped at a light the car shudders for two to three seconds, otherwise engine performs well.
Aug 17, 2018 at 8:44 AM
DANNY L
✓Experienced Mechanic
Hello, I am Danny.
Have you performed the regular performed maintenance? With this car being turbo oil changes really do make a difference. Engine oil still does control turbo performance. Is the drain back into sump clogged? It does make a huge difference. Oil changes make hugh differences including CKP and CMP readings. Hope this helps and feel free to ask any other questions.Thanks for using 2CarPros.
Danny-
Aug 17, 2018 at 9:08 PM
STEVERINO84
MEMBER
Thanks Danny. I forgot to ask if changing the spark plugs might be the answer. I bought car used with 36,000, now has 50,000. Thanks again.
Aug 17, 2018 at 10:48 PM
STEVERINO84
MEMBER
Thanks Danny, one additional question on 2012 Juke, on car shudders one to two seconds at stop light or while idling in park. Could it be bad spark plug(s) or injector or wires. I filled it with premium gas, which seemed to reduce the shudder. Otherwise car runs fine, gets around 23 mpg, with a lot of short trip driving. Thanks for your help.
Aug 20, 2018 at 4:28 AM
DANNY L
Hello again,
If you bought the car used and it has 50,000 miles now I would guess they are original. It would not be a bad idea to change them and see if it gets rid of the stutter. Hope this helps and thanks for using 2CarPros.
Danny-
Aug 20, 2018 at 1:59 PM
STEVERINO84
MEMBER
Hi again, one more item to add on that shudder in my engine. It only occurs when the A/C is on. Thanks again.
Aug 21, 2018 at 3:03 PM
DANNY L
Hello again.
Can you upload a video from your phone/smartphone showing the condition? Vibration will always be noticed with the A/C system activated. If it is out of the ordinary then that would be a problem. Hope this helps and let me know if you can. Thanks again for using 2CarPros. Will await your response.
Danny-
Aug 23, 2018 at 4:57 PM
STEVERINO84
MEMBER
Hi, thanks again for the reply. But the vibration is only noticeable not by sight, but from sensation. When stopped at a light, only lasts for two seconds, and only with the A/C on. Could it be when the compressor kicks on and off?
Aug 24, 2018 at 11:14 AM
DANNY L
Hello again.
Yes, that is what it sounds like is happening. Thanks again for using 2CarPros.
Danny-
Aug 24, 2018 at 4:40 PM
STEVERINO84
MEMBER
Thanks again Danny, take care.
Aug 25, 2018 at 3:36 PM
DANNY L
You are welcome!
Feel free to use us again anytime and thanks again for using 2CarPros.
Danny-
