Snow mode or any of the others doesn't change the transmission engagement operation. It just changes shift points and other things but we need to check for codes. I am not sure how this would have happened or is related to the snow mode engagement. I think that is more of a coincidence.
Clearly if it didn't go back into gear, you had to have it towed. Did you tow it to a shop or back home? Do you have the ability to check codes? If there are no codes then we need to check fluid level and see where it is and the condition of the fluid.
I included the process on how to change the fluid and filter if it is low or in poor condition.
Images (Click to enlarge)
Mar 31, 2021 at 2:38 AM
(Merged)
