traction control comes on by itself?
MIKELLWILLIAMS2015
About 5 years ago I hit a curb and it bent my right rim, and now when I drive between 30 and 50 MPH it starts to shake. another problem that occurs is that if I turn my steering wheel to a certain point the traction control light comes on. I've had the wheels replaced and balanced still hasn't fixed it. do you think you know what's happening? Thanks in advance.
Nov 13, 2015 at 2:56 AM
More then likely this is a steering angle sensor or a wheel speed sensor is not reading correctly so when you turn the wheel it tells the ABS that the traction control needs to activate so it does.
Here is a video that helps explain why this is happening:
https://youtu.be/K5AJVMk4U8Q
Also, here is a guide that will help with testing the wheel speed sensors:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
The only other thing we need to do first is check for codes.
https://www.youtube.com/watch?v=rTtAnsOlZU4
Let us know what you find and we can go from there. Thanks
Jan 17, 2021 at 8:37 AM
